Author Topic: 77 W72 trans am Restoration (roof swap)  (Read 75832 times)
Re: 77 W72 trans am Restoration (roof swap)
« Reply #45 on: January 31, 2010, 02:02:21 PM »
the die and primer is all DUPONT
been working on the shifter off and on for a few days , here is what I got.
the last few days I worked on the steering column. the batteries in the camera went dead, so no pics. I took it completely apart. cleaned it, new grease, stripped and re-paint. then put it back together. wet sand it and cleared.   I did that after it was together, just in case I got scratched. here is the after pics.
now all it need's is Randy's gold spoke wheel. and this part is done.
cwi inspector
« Reply #46 on: January 31, 2010, 07:35:43 PM »
4speed your dash is looking awsome. Do you know of anyway to repair the opening for the radio. Mine was cut out for an after market and I would like to put an original back in.
« Reply #47 on: February 06, 2010, 01:24:02 AM »
yes find a old cheap cracked dash that has the radio not cut. cut it out of the dash ( big ) . then using a grinder trim it until it fits. use a good epoxy to attach it to the dash.  you need to take your dash out to do this, so you can see the fit of it on the inside. then you can lay fiber glass & resin around it on the inside.
you may find one on here. post it in parts wanted.  just ask for the radio part you need. cut it big . and will save on shipping.
« Reply #48 on: February 10, 2010, 01:14:23 PM »
I have this in the parts for sale to
from an 80 t/a
Greenville , Ohio 45331  llester3@woh.rr.com
« Last Edit: March 01, 2010, 12:36:23 AM by 4SPEED »
gorin002
« Reply #49 on: February 12, 2010, 01:20:14 PM »
its like a big scale model kit
man i wish i could do it allll
« Reply #50 on: March 01, 2010, 01:00:21 AM »
here is ware I'm at with the motor  77 W72 . once I get the motor done, I will start the rebuild of the th350 trans. It will take the rest of the winter and spring to complete. I will be gasket matching , port and polish on the heads. gasket match the intake. and paint the inside of the block with Glyptal  http://www.caswellplating.com/aids/glyptal.html
gorin002
« Reply #51 on: March 02, 2010, 04:23:28 AM »
so first you paint it all with this primer ?
« Reply #52 on: March 05, 2010, 04:02:52 AM »
you dont need to but the block ,after it has been shot blasted is not smooth any more.  the Glyptal  fills in and smooths out the block so the oil will run back to the pan better.
gorin002
« Reply #53 on: March 11, 2010, 01:42:05 PM »
so whats primer for ?
paint primer the body first ?
« Reply #54 on: March 12, 2010, 01:43:33 AM »
you do not put the Glyptal on the smooth machined area of the block.
gorin002
« Reply #55 on: March 17, 2010, 04:13:33 PM »
whats the primer for ?
also notice you have a big garage
we have garage wich so small
« Reply #56 on: March 18, 2010, 04:44:01 AM »
the primer on the dash?   it bites into the vinyl on the dash , and gives the pant something to bite into. if you didn't  prime the dash first the paint would flake off, in time.
gorin002
« Reply #57 on: March 18, 2010, 06:47:09 AM »
okay.only for the dash
and body metal work how do tread that only paint ?
« Reply #58 on: March 26, 2010, 07:31:14 AM »
got the 400 built last weekend and painted.
SpankinElroy
« Reply #59 on: April 01, 2010, 09:28:43 PM »
This is one of the most insane restorations I've ever seen!....I am absolutely berzerk with envy!! :D - to have such a great car, the facilities, the cash and the know-how all under one roof is a rare combo indeed. Hats off to you pal and keep up the great work...sooo looking forward to this sweet machine's happy ending  ;D
