Author Topic: HPTUNERS VCM Suite | Performance at Your Fingertips  (Read 12249 times)
TunerTools
  • Tuner Tools, the Inside Line
    • Tuner Tools - the Inside Line
« on: May 07, 2011, 03:33:34 PM »
Tuner Tools LLC is now a fully stocking and authorized distributor for HP Tuners
Setting the Industry Standard
HP Tuners VCM Suite package sets the industry standard with lightning fast VCM/PCM reads and writes. No other commercial package today can provide you with better ease of use, data integrity or higher reliability than the VCM Suite tuning package.
VCM Suite Product Information | Supported Vehicles | VCM Enhancements | VCM Scanner
HP Tuner VCM Suite Product Information
The VCM Editor utility is a comprehensive VCM/PCM programmer and parameter editor.
VCM Editors Flash utility allows the user to read the VCM/PCM flash memory and save it to a binary file. The Flash utility allows a valid calibration to be written to the VCM/PCM and also incorporates an automatic VCM/PCM recovery capabilities for ultimate protection against any reflashing problems that may be encountered.
The VCM Editor also allows modification of the saved binary image. The VCM Editor allows all parameters such as Spark, Fuel, RPM Limits, FAN Temps, Transmission Shift points and pressures, Speedometer settings and many, many more. The editor provides an easy to use graphical interface and many powerful table manipulation capabilities such as copying, scaling and shifting to name a few.
* View the Full Features List
* Order VCM Suite Now!
So you're probably thinking, what else could there be for a professional tuner? Well, read on...
The VCM Suite has certain features that a professional tuner may find more useful. It includes some of the following extra capabilities.
VCM Editors Flash utility allows not just calibration reflashing and automated recovery, but entire VCM/PCM image reflashing. This means that you are free to make any operating system or calibration level modifications and flash those to the VCM/PCM. This has many uses for the advanced enthusiast, serious tuner or engine swap shop, allowing complete control over the VCM/PCM software environment.
The VCM Editor also allows for increased vehicle support for tuners, and also access to extra VCM/PCM operating system code modifcations. Tuners also have the option to modify VIN's, a useful feature for mail order VCM's.
Security. Protect your tunes with Tunerlock. Only you have the ability to read and write to VCM/PCM's that you have Tunerlocked. Prevent unwanted access to your hard work.
The VCM Scanner utility is a fully featured OBDII scanning and diagnostic tool.
It allows viewing, charting and logging of diagnostic data in real time via the vehicle OBDII diagnostic data port. It also allows viewing of vehicle Diagnostic Trouble Codes (DTC's) and other vehicle information. Built in VCM controls also supported. Command fans, closed loop, gear select, timing, air fuel ratio and more real time! No editor package can be considered complete without comprehensive scan tool capabilities.
VCM Suite is the complete package.
These components combine to make VCM Suite the most feature rich, powerful and comprehensive VCM/PCM reprogramming and diagnostics package available on the market today. In addition, our attractive make/model/year based licensing structure makes VCM Suite a clear leader in value for money.
Buy Your VCM Suite Tuning Package here
VCM Suite is the ultimate tuning tool designed for your serious tuner and tuner shop.
Cheers,
Lloyd
www.TunerTools.com
