Join or renew for 3 years and receive a free t-shirt
or tech sections on USB flash drive /emailed/CD or past Eagle issues on USB flash drive/emailed/CD
see details in the join the club section at www.firebirdtaclub.com!
Fuel Pump Replacement
Started by november2021, November 15, 2021, 12:24:08 PM
Previous topic - Next topic
november2021
In search of some help please. I put a brand new fuel pump in a 1980 Trans Am. While there seems to be good pressure it simply will not draw fuel. I did put a couple gallons in the empty tank and still nothing. The car has been sitting since 1999 until I purchased it. I am now trying to get it to run. Any ideas?
If you put fuel down the carb fires right up but it simply will not draw any fuel.
Jason Pittman
firebirdclub
Unhook the fuel line going into the fuel pump then blow compressed air into the fuel tank by removing gas cap and use a rag be careful not to blow to much psi until the line blows clean.
Also you may want to replace the fuel line and make sure there are no obstructions in the tank. Then try hook up lines to a gas can and see if  it works. If it does, blockage is between the tank and pump.
Mechanical fuel pumps use a lever that rides on the camshaft to pump a rubber diaphragm inside the pump up and down. This creates suction that pulls fuel into the pump, and then pushes it along. A pair of one-way valves inside the pump only allow the gas to move in one direction (toward the engine).
William Echols
National Firebird and Trans Am Club
website: www.firebirdtaclub.com
email: info@firebirdtaclub.com
phone/text: 773-769-7166
North America's oldest and largest club for all Firebirds and Trans Ams including GTAs and Firehawks.  Established in 1984 and offers color magazines (EAGLE), emagazines, technical advice, free member classifieds, member repair shop recommendations and much more!
back to NFTAC website home page or NFTAC Photo Gallery or NFTAC Club Blog
