Author Topic: Tail fuse  (Read 3868 times)
84recarogirl
Tail fuse
« on: May 17, 2007, 03:20:14 PM »
I've been having this problem for a few weeks now. When I go to turn on my headlights, my tail fuse blows. Every time. So now because of this I can't drive at night. I've traced all the wires and can't find a short to ground and i've ohm'd everything and all seem to check out ok. What else could be causing that short. Yesterday, I found out that the battery was too big for the car, and so I bought a new one hoping that the new batt would also fix my headlight issue. But no luck.
If anyone has ever had this problem before, it would be great to know how to fix it.
I have a 84 T/A Recaro with the V8 305.
Re: Tail fuse
« Reply #1 on: May 22, 2007, 09:13:56 PM »
HI:
The Fuse Blown Blues!
Assuming you did the basic preliminary and you are certain the wires, wire harness is in good condition, not frayed, no loose connections, no added high powered accessory taped in etc. try inspecting and / or replacing the light switch assembly sometimes thou rare the light switch assembly can be come defective in time.
Also by having a battery that is to big ie. // a battery that has mega- cold-cranking amps will not help prevent a shorting condition.
                          Hope This Helps  ;D
Bill Simcox
Re: Tail fuse
« Reply #2 on: May 25, 2007, 07:48:34 AM »
To add a note to Justin's email about rare instances of blown fuses.  Although rare, I have found several cases where a defective bulb caused blown fuses. If you haven't already done so, visually check all the running lights and see if you maybe have a dislodged filament causing your problem.
I hope you are able to find the problem quickly, because day light only crusin' isn't the best thing that can happen, especially this time of year.
Bill
Re: Tail fuse
