EGR CODES
Started by KAKES, June 09, 2007, 08:15:47 AM
KAKES
I HAVE A 99 PONTIAC FIREBIRD AND I HAVE AN ERG LOW FLOW CODE. I HAVE REPLACED THE EGR VALVE AND THE CODE CAME BACK...ANY BODY HAVE ANY SUGGESTION ABOUT WHAT I SHOULD DO NEXT?
P.S.
THE CAR DOESN'T RUN BAD AT ALL EVEN THOUGH THE CHECK ENGINE LIGHT IS ON...
HI:KAKES
Yes in addition to making the repair you have to erase the trouble Codes that is stored in your cars OBD II computer ( ECM ) Electronic Control Module with either a Tech II Diagnostic computer or Auto Scanner and if the code comes back the first step is to check the circuit; wiring for shorts, Loose Connections etc. an also check the EGR for proper sealing and for vacuum leaks in the area / and re-check the ECM for any additional Trouble Codes
                          Hope This Helps
TunerTools
One follow up:  Clearing the code does not require specifically the Tech II Diagnostic computer or Auto Scanner as this can be done with just about any functional OBD-II Scan Tool, including some that are much less expensive than the Tech II
Links below to several under $150 and some less than $100
OBDpro Scan Tool Kits
ElmScan 5 Scan Tool Kits and accessories
ScanGauge II - 3 in 1 Engine Computer, Scan Tool & Digital Gauges
Cheers,
Lloyd
www.TunerTools.com
b1er
was the code cleared during the fix?.....if not it could take a few readiness (start) cycles to clear....
or you could find someone with a tuning program to turn the codes off and dump the whole system....
99 TA
01 TA WS6 vert
