Author Topic: transmission or engine?  (Read 6043 times)
insomnia
« on: July 07, 2007, 01:20:23 PM »
I'm not sure if my engine is seized up or my transmission is at fault.  What is the easiest way to disengage or tell if my transmission is engaged?  Please reply
craig
Re: transmission or engine?
« Reply #1 on: July 09, 2007, 07:41:45 PM »
HI: Craig
Transmission or Engine Seized / That Is The Question??
The easiest way to tell if you have Transmission trouble is if your engine is running and if it is in drive or reverse and you step on the gas a little and you don’t move or hardly move // You have Trans., trouble!!
 Hope This Helps
rangernut09011980
« Reply #2 on: November 21, 2009, 01:50:11 PM »
the easiest way i know of is to remove the torque convertor to flywheel bolts and try to start engine if the car has been sitting for an extended period of time   pull the plugs  use an air blower and blow out all of the cylinders  and make sure they are not full of fuel  the engine may be seized from sitting (damned rust) mine was!!!  after blowing out the cylinders buy a gallon can of WD40 and some marvel mystery oil put some WD40 in all of the cylinders and let it sit for a few days this will start to break up the rust follow that with the marvel mystery oil and let it sit for a few more days  then try to spin over the engine and see if it has freed up I put mine on jack stands and ended up using a jack and a flat head screwdriver to rotate the engine at the flywheel mine had sat for almost 3 years now it is freed up and spins over quite nicely
