Author Topic: Blown fuses--Help  (Read 3994 times)
Ersel
Blown fuses--Help
« on: October 13, 2008, 04:37:58 PM »
Hi!
I just purchased a '74 Bird and the brake lights do not light up.  I noticed the fuse was blown and quicly replaced it.  As soon as I applied the brakes the fuse blew.  How would I go about tackling the short & finding the problem?
Thanks in advance.
clayton
Re: Blown fuses--Help
« Reply #1 on: October 13, 2008, 06:39:16 PM »
it sounds like its a dead ground. check around the tail lights to see if any wires wore out and are touching the body somewhere they shouldnt be....a multi meter will help check to see which wires should be grounded and which ones shouldnt.....it will help alot to know if the previous owner has done any work to the wiring. if so try and find out whats been done and you should know about where to start.....or even check the tail light bulbs to see if they installed the right bulbs or if theyre bad or if there is something wrong with the bulb sockets such as water, debris etc. that could cause shorting......
i hope i helped
clayton
Ersel
« Reply #2 on: October 14, 2008, 11:23:57 AM »
I will check on that in the next two days.  I looked at the fusebox and it looks like someone monkey'd with it, since one of the cooper tabs is missing on the dash lights fuse.  Not sure if the fuse was rerouted but my dash lights do not work either.  Hmmm
Thanks for the feedback
